Dear all,
I have a very troubling question. All of my monitored servers alert at 6 am every day.I checked the icinga2 server log:
Dec 19 06:10:31 vgchuvicgamasp01 sssd: Killing service [ssh], not responding to pings!
Dec 19 06:10:43 vgchuvicgamasp01 sssd: Killing service [nss], not responding to pings!
Dec 19 06:11:31 vgchuvicgamasp01 NPCD[75327]: ERROR: Executed command exits with return code ‘7’
Dec 19 06:11:31 vgchuvicgamasp01 NPCD[75327]: ERROR: Command line was ‘/usr/lib/pnp4nagios/libexec/process_perfdata.pl -n --bulk /var/spool/icinga2/perfdata/service-perfdata.1576706991’
Dec 19 06:11:31 vgchuvicgamasp01 sssd: [ssh][89174] is not responding to SIGTERM. Sending SIGKILL.
Dec 19 06:11:33 vgchuvicgamasp01 NPCD[75327]: ERROR: Executed command exits with return code ‘7’
Dec 19 06:11:33 vgchuvicgamasp01 NPCD[75327]: ERROR: Command line was ‘/usr/lib/pnp4nagios/libexec/process_perfdata.pl -n --bulk /var/spool/icinga2/perfdata/host-perfdata.1576706991’
Dec 19 06:11:43 vgchuvicgamasp01 sssd: [nss][103661] is not responding to SIGTERM. Sending SIGKILL.
Dec 19 06:11:47 vgchuvicgamasp01 check_radius: rc_get_seqnbr: couldn’t get lock after 10 tries: /var/run/radius.seq
Dec 19 06:12:09 vgchuvicgamasp01 check_radius: rc_get_seqnbr: couldn’t get lock after 10 tries: /var/run/radius.seq
Dec 19 06:12:11 vgchuvicgamasp01 sssd[nss]: Starting up
Dec 19 06:12:37 vgchuvicgamasp01 sssd[ssh]: Starting up
Dec 19 06:13:03 vgchuvicgamasp01 NPCD[75327]: ERROR: Executed command exits with return code ‘7’
Dec 19 06:13:03 vgchuvicgamasp01 NPCD[75327]: ERROR: Command line was ‘/usr/lib/pnp4nagios/libexec/process_perfdata.pl -n --bulk /var/spool/icinga2/perfdata/host-perfdata.1576707034’
Dec 19 06:13:03 vgchuvicgamasp01 NPCD[75327]: ERROR: Command line was ‘/usr/lib/pnp4nagios/libexec/process_perfdata.pl -n --bulk /var/spool/icinga2/perfdata/service-perfdata.1576707021’
I changed the timeout value of the “/etc/pnp4nagios/process_perfdata.cfg” to 60 ,but my problem remained unresolved。
If anyone has a solution, please give me some hints. Thank you!
[root@icinga2server01 ~]# icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: v2.5.4)
Copyright © 2012-2016 Icinga Development Team (https://www.icinga.org/)
License GPLv2+: GNU GPL version 2 or later http://gnu.org/licenses/gpl2.html
Application information:
Installation root: /usr
Sysconf directory: /etc
Run directory: /var/run
Local state directory: /var
PID path: /var/run/icinga2/icinga2.pid
System information:
Platform: Red Hat Enterprise Linux Server
Platform version: 6.10 (Santiago)
Kernel: Linux
Kernel version: 2.6.32-754.6.3.el6.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 4.8.2
Build host: 10525b1d9830
