Notifications with Director
  • Director version (System - About): 1.11.4
    icinga-php-library 0.7.0
    icinga-php-thirdparty 0.10.0
  • Icinga Web 2 version and modules (System - About): 2.9.5
    PHP Version 7.3.20
    doc 2.9.5
    incubator 0.22.0
    ipl 0.5.0
    map 2.0.0
    monitoring 2.9.5
    reactbundle 0.9.0
  • Icinga 2 version: r2.14.3-1
  • Operating System and version: CentOS 8
Hello
I have an instance of Icinga 2 with Icinga Web 2 running on CentOS 8. All the records and configurations were made through the files in /etc/icinga2/conf.d and others, and everything is working as expected. I am now in the testing phase, an instance on another server, with the same versions I mentioned, but with all the configuration through Director, I already have hosts, host groups and templates, dependencies, etc. I am now having difficulties with notifications, I installed Postfix and have already tested sending successfully through the icinga2 command line, but I am not able to send emails through icinga Web 2.
Can anyone help me with the versions I indicated?
Thanks and good work
