Hi team!
I have SMS notification configured with a period of 9-18, everything works fine. But I don’t understand the monitoring behavior, when the host goes into a hard state, for example, at 21-00, and remains in it until the notification time, then I receive an SMS. How can I make sure that I receive notifications that only happened in the notification interval? I considered the option of setting the check period in the host, but decided against it, since I still have mail notifications that should work 24x7
I would suggest that you update the notification command and modify or wrap the sms notification tool.
If you tell the new director command the notification times → your wrapper can decide to send the sms or not.
