Hi
I have two questions
I have set up notification in direcor:
Mytemplate
template Notification "Benachrichtigungsvorlage Service" {
command = "mail-service-notification"
interval = 2m
states = [ Warning ]
types = [
Acknowledgement,
Custom,
DowntimeEnd,
DowntimeRemoved,
DowntimeStart,
Problem,
Recovery
users = [ "Koda" ]
Notification:
apply Notification "t1" to Service {
import "Benachrichtigungsvorlage Service"
assign where match("*", host.address)
users = [ "Koda" ]
Under Overview contacts, I see Koda, but in the details I see No notification was send
For Mail: Can I setup this for smtp?
Givs a change for notification with Pushover and Director? I have found this https://git.dinven.de/Monitoring/icinga-plugins/src/branch/master/notification/pushover but cant create the command in Director because I can’t insert ENV Variables
Because finally, you only enter a script at the notficiation command definition, which does the notification. That means the script does the magic and for that you have the parse every argument what it need. For Icinga (Director) it doesn’t matter what the script is doing. That means the script can send a SMS, using a messanger service, sends a mail etc. In the history in icingaweb you see only that the notification is done for person xy.
