Not quiet sure how to update icinga2
Hello everyone!
I’ve read the news stating to update icinga2 due to security issues. As I’m very new to monitoring and Linux in general I would like to know what I need to update on my master (Ubuntu) and agents (Ubuntu and Windows).
I’ve read the documentation and the troubleshooting section but I still don’t understand if I only need to run these commands for my Linux master and agents:
sudo apt-get update
sudp apt-get upgrade
and this command for Windows agents:
Update-Icinga;
Is this it? Or is there something else I’m missing out? And what about EOL distributions? How does it work there?
Any help would be appreciated!
Reading Icinga 2 Security Pre-Announcement should help a lot.
But if you have the icinga repository activated then reloading and updating should do the trick.
Thanks for using Icinga and asking your question.
For the Ubuntu part, the apt-get upgrade should be enough if you are using Icinga’s repository. To make sure, verify the icinga2 --version afterwards.
For Icinga on Windows, the Update-Icinga command should do the trick.
To verify that all your Icinga 2 installations are running the latest version, you could utilize the icinga Check Command with icinga_min_version set to 2.14.3.
