Hi Icinga Community,
I am automating the icinga agent set up and therefore calling the node setup command.
In the docs node-setup-with-agentssatellite it reads: -
Pass the following details to the node setup CLI command:
Parent endpoint Required. Specify the parent’s endpoint name.
When I pass the --parent_endpoint I get this error:
critical/icinga-app: Error while parsing command-line options: unrecognised option '--parent_endpoint'
icinga2 agent version: 2.11.4-1
Kind regards
Peter
