Hi there,
we have host-templates with a suffix “-ext” to be assigned to all hosts we want to monitor but which are not “controllable” by ourself, e.g. for XaaS-services we get.
I now wanted to use assign services by apple-rules / assign-where using wildcards with wildcards. Unfortunately it seems as the operator contains does not support wildcards?
I even tried (also did not expected that it will work) in operator.
Is there really no way to use wildcards in assign-where on array attributes as host.templates?
To be more precise:
contains works with value without wildcard, but there seems not to be a way to define complex enough assign rules for array if you want to express something as, assign where:
- a template “net-*” is imported, but NOT
- if a template with “net-*-ext” is imported
I tried so many several ways, including this as
- AND
- NOT
- host.templates contains
ext
net
- NOT
and other derivates of it…
Best,
Matthias
