Hi guys,
we are using Icinga for Windows for a while now and works very well for us !
Lately I have enabled the communication between the Icinga master and the IfW clients directly via API calls.
What I really liked, was the performance, execution of checks was much faster.
But just today I realized, that I can no longer set warning/critical thresholds for checks in Icinga Director - they are ignored.
I am using for example the “Invoke-IcingaCheckCPU” command and have a service template where I set the thresholds. But I am not able to see this variables in the curl command and they just do not work.
I have switched back by no longer loading “ifw-api” in the “Powershell Base” command and thresholds are working again.
Can you tell me what I have missed?
Best regards
Volke
This is my system:
- Icinga for Windows output (
Show-Icinga)
PS H:> Show-Icinga
Icinga for Windows environment:
Environment configuration:
PowerShell Root => C:\Program Files\WindowsPowerShell\Modules
Icinga for Windows Service Path => C:\Program Files\icinga-framework-service
Icinga for Windows Service User => NT Authority\NetworkService
Icinga for Windows Service Pid => 6072
Icinga for Windows JEA Pid =>
Icinga Agent Path => C:\Program Files\ICINGA2
Icinga Agent User => NT AUTHORITY\System
Defined Default User => NT AUTHORITY\System
Icinga Managed User => False
PowerShell Version => 5.1.17763.6530
Operating System => Microsoft Windows Server 2019 Standard
Operating System Version => 10.0.17763
JEA Context =>
JEA Session File =>
Api Check Forwarder => True
Debug Mode => False
Icinga for Windows Certificate:
Issuer => CN=Icinga CA
Subject => CN=
List of configured background daemons on this system:
Start-IcingaWindowsRESTApi
No arguments defined
List of configured background service checks on this system:
=> Collect Metrics Over Time - Icinga for Windows
No background service checks configured
List of configured repositories on this system. The list order matches the apply order:
Icinga Stable Local
CloneSource =>
Enabled => True
LocalPath =>
Order => 0
RemotePath => http:///IcingaForWindows/stable/ifw.repo.json
UseSCP => False
Installed components on this system:
Component Version Available
agent 2.14.3 2.14.3
framework 1.12.3 1.12.3
plugins 1.12.0 1.12.0
service 1.2.0 1.2.0
Available versions flagged with “*” mean that this component is locked to this version
PS H:>
- Version used (
icinga2 --version)
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.14.3-1)
License GPLv2+: GNU GPL version 2 or later https://gnu.org/licenses/gpl2.html
System information:
Platform: Rocky Linux
Platform version: 8.10 (Green Obsidian)
Kernel: Linux
Kernel version: 4.18.0-553.27.1.el8_10.x86_64
Architecture: x86_64
Build information:
Compiler: GNU 8.5.0
Build host: unknown
OpenSSL version: OpenSSL 1.1.1k FIPS 25 Mar 2021
Application information:
General paths:
Run directory: /run/icinga2
Old paths (deprecated):
Installation root: /usr
Sysconf directory: /etc
Run directory (base): /run
Local state directory: /var
Internal paths:
- Operating System and version
- Enabled features (
icinga2 feature list)
Disabled features: compatlog debuglog elasticsearch gelf influxdb journald opentsdb
Enabled features: api checker command graphite icingadb ido-mysql influxdb2 livestatus mainlog notification perfdata syslog
Icinga Web 2 version and modules (System - About):
Icinga Web 2 Version 2.11.4 -
Config validation (
icinga2 daemon -C) - all green -
If you run multiple Icinga 2 instances, the
zones.conffile (oricinga2 object list --type Endpointandicinga2 object list --type Zone) from all affected nodes
