in my case i use two satellites in one cluster zone and one master where icinga web 2 is installed. When i check a network device via command line then i get values.
When i use my service template, i got the output of “< Timeout exceeded. > <Terminated by signal 9 (Killed).>”
if you try a manual snmp query or a complete snmp walk? Does this work or you get here also a timeout?
Sometimes we have also similar problems with the nwc check. Sometimes it is due to the following causes:
The network hardware is to slow or is working a lot at the moment (cpu load)
the internet bandwidth to the other office is just exhausted at the moment of the check (e.g. users are downloading windows updates etc.)
To many interfaces to check - also in combination of one of described the previous problems
