Hi team,
we are using the official CentOS 8 repo for icingaweb2:
https://packages.icinga.com/epel/$releasever/release/
But we stuck on version 2.9.5 because the repo doesn’t contain any newer version:
dnf upgrade fails with “nothin to do - Package icingaweb2-2.9.5-1.el8.icinga.noarch is already installed.”
Because I am very impatient I updated manually to 2.10.1 (Just replaced the PHP files in /usr/share/icingaweb2) but then there is a php error in the icinga.min.css file which says:
.appearance is undefined in anonymous-file-0.less
#0 /usr/share/icingaweb2_new/library/vendor/lessphp/lib/Less/Tree/Ruleset.php(143): Less_Tree_Mixin_Call->compile()
#1 /usr/share/icingaweb2_new/library/vendor/lessphp/lib/Less/Tree/Ruleset.php(86): Less_Tree_Ruleset->EvalMixinCalls()
#2 /usr/share/icingaweb2_new/library/vendor/lessphp/lib/Less/Tree/Ruleset.php(91): Less_Tree_Ruleset->compile()
#3 /usr/share/icingaweb2_new/library/vendor/lessphp/lib/Less/Parser.php(185): Less_Tree_Ruleset->compile()
#4 /usr/share/icingaweb2_new/library/vendor/lessphp/lessc.inc.php(130): Less_Parser->getCss()
#5 /usr/share/icingaweb2_new/library/Icinga/Web/LessCompiler.php(230): lessc->compile()
#6 /usr/share/icingaweb2_new/library/Icinga/Web/StyleSheet.php(218): Icinga\Web\LessCompiler->render()
#7 /usr/share/icingaweb2_new/library/Icinga/Web/StyleSheet.php(258): Icinga\Web\StyleSheet->render()
#8 /usr/share/icingaweb2_new/library/Icinga/Application/webrouter.php(64): Icinga\Web\StyleSheet::send()
#9 /usr/share/icingaweb2_new/public/index.php(4): require_once('...')
#10 {main}
.. pad * 2) / .857;
.pagination-control {
li > a {
color: var(--control-color, @control-color);
border-radius: .25em;
li > a:hover {
background: var(--control-hover-bg, @control-hover-bg);
.previous-page,
.next-page {
padding: .5em .25em;
i {
display: block;
i:before {
margin: 0;
.previous-page > i {
margin-left: -.125em;
.next-page > i {
margin-right: -.125em;
// Style
.control-button {
!! .appearance(none);
background: none;
border: none;
.rounded-corners();
&:hover, &:focus, &.active {
background-color: var(--control-hover-bg, @control-hover-bg);
text-decoration: none;
&.disabled {
color: var(--control-disabled-color, @control-disabled-color);
&:hover {
background: none;
i.icon:before {
color: inherit;
// Layout
.control-button {
display: inline-block;
padding: .25e
I can’t find this setting when I grep for it.
Enabled modules:
director
doc
graphite
idoreports
incubator
ipl
migrate
monitoring
pdfexport
reactbundle
reporting
vspheredb
What can we do to perform an upgrade?
I read https://icinga.com/docs/icinga-web-2/latest/doc/80-Upgrading/#upgrading-to-icinga-web-2-210x but couldn’t find any helpful hints.
Thanks an kind regards
Markus
