Good day everybody,
i’m very new to Icinga that i’ve installed today (with some freaky moments:).
I’m looking for a complete system that monitors win/linux hosts and acts like a Syslog server. It’s Icinga ok with that? How can i send, in exemple, CISCO ASA logging to Icinga? Is that possible?
As i understand it, it’s two different needs that need separately two different tools, Icinga will make the job for monitoring win/linux hosts, but it is not meant to store logs. For that part i’d advise you going for an ELK stack (Elastic, Logstash, Kibana) or a paid solution like Splunk.
for receving syslog messages (and maybe also SNMP Traps) you need only logstash from the ELK stack. Logstash has a lot of import and export plugins.
For Syslog syslog messages you need this one: https://github.com/logstash-plugins/logstash-input-syslog
For shipping and visualizing to/in icinga you only need this plugin https://github.com/logstash-plugins/logstash-output-icinga
If you don’t want to filter messages, you only need to install and configure logstash and these two plugins. We for example had create filter rules in logstash for a storage, because this one send every message (useful or not) not our icinga server. And it was not possible on storage to configure this.
