Network Interface Traffic via SNMP shows spikes on reboot
Hi
We’re monitoring a bunch of Ubuntu Linux VMs and one of the default checks applied is a network interface traffic check, performed via check_snmp, executed through the Icinga2 agent on the monitored server (so SNMP to localhost + just delivering the result back to the master).
This works fine, since 3+ years and all was good. Then we noticed strange values in the charts, when testing a host’s performance / network limits. The charts never showed the full value - but e.g. iperf3 on the CLI showed that the host performed well and as expected.
After some research we found that we used the 32 bit counters (ifInOctets or 1.3.6.1.2.1.2.2.1.10.x) and not the 64 bit counters that we should have used (ifHCInOctets or 1.3.6.1.2.1.31.1.1.1.6.2). We switched those OIDs in the monitoring config, configured the check to be via SNMP v2c (instead of v1 which does not provide the new OIDs). After that, the tests and the charts now showed the same output and we were happy and left it like this.
But over time, we noticed strange spikes in the charts (a server that usually moves traffic in the Kbits/s to some MBits/s range showes a short spike of traffic in the PetaBits/s range). At first we ignored it, but later found out it always happens when rebooting the VM.
We tried to automatically remove the state file of check_snmp prior to reboots to make sure this problem does not happen again - did not really solve the issue.
So I’m a bit lost and out of ideas: Does anyone know what happens here and how we could approach this to get it resolved?
How do you monitor network interfaces traffic for linux servers?
Mario
Could this be because it is not a normal value but a counter and on reboot it gets reset and thus the delta is in PetaBits/s?
We are using a self written check plugin that is evaluating /proc/net/dev.
Depending on your needs by using
  • our Linuxfabrik Monitoring Plugin snmp
  • or by using LibreNMS and “integrating” it by using our Linuxfabrik Monitoring Plugins for LibreNMS named librenms-alerts and librenms-health
Thanks to all of you for your hints and ideas!
In the end, we gave up on fixing the issue at the source of the problem and just “fixed” the charts in grafana, by filtering out values above the maximal physical connection available. Result was the following:
We just add
... AND value < X
to the InfluxDB queries. And let X be a number like 10737418240 which should be the limit for e.g. a 10Gbit/s based infrastructure.
It’s not a super sexy solution, does not use machine-learning or AI to detect and filter out outliers - but it filters out values that are obviously not possible (like seeing Petabits/s of traffic on a 10Gbit/s interface).
