hi community
please note
i am using icinga2 and netbox, when i remove hosts from netbox the change is not reflected in icinga and vice versa…using icinga deployment changes it keeps failing
appreciate your assistance if there is a configuration file i need to update to sync the changes
when i try and deploy changes below is the error message
