Hi.
Is there a way to iterate over multiple vars/have nested for loops in an apply rule (Service)?
I have a check for HTTP/HTTPS redirect, which expects different locations depending on the useragent. Also the HTTP/HTTPS check should check multiple domains.
Inside the domain/vhost dict the redirects and useragents are defined, but also the timeouts etc. which I use inside of the Service.
So it would be something like:
apply Service "HTTP useragent" for (var vhost => var config in host.vars.nginx) for (var useragent => var redirect in config.user_agent) { ... }
This does not work obviously.
Thanks in advance
