Hi Team,
can you please provide me any example configuration as i want to monitor on remote server which is running on HPUX platform.
so i am using check_by_ssh module by nagios in icinga, so need sample configuration
examples as i have setup password less connection into my icinga master server and remote server.
@mfrosch : can you help the same.
BR,
GauravS
Example:
apply Service "linux_partitions" {
display_name = "Linux Partitions"
check_command = "by_ssh"
vars.by_ssh_command = "/usr/lib/nagios/plugins/check_disk"
vars.by_ssh_logname = host.vars.ssh_username
vars.by_ssh_arguments = {
"-w" = "20%"
"-W" = "20%"
"-c" = "10%"
"-K" = "10%"
"-x" = [
"none",
"tmpfs",
"sysfs",
"proc"
assign where ...
Hey there,
I suggest to use a custom check_command for that, when you have the ability to use normal configuration.
object CheckCommand "disk_by_ssh" {
import "disk"
import "by_ssh"
vars.by_ssh_command = "$custom_plugin_dir$/check_disk"
vars.by_ssh_arguments = {{ get_check_command("disk").arguments }}
In this case you have all arguments from the original disk check available and you can customize the plugin dir to the HPUX path. something like /opt/csw i guess?
If you are using the director, try to import the command from the api.
Example Service:
object Service "Partition /root"
import "generic-service"
check_command = "disk_by_ssh"
vars.disk_partition = "/root"
