Hi guys,
i did install the nagvis module as described here: https://dokuwiki.nausch.org/doku.php/centos:web_c7:icinga:nagvis
It seems to be working and looks like this currently:
However, i am missing options (top bar, options and actions), should look like this:
I think i am not an admin. I dont have the option to log out (it logs me in automatically). in icinga2 (configuration --> authentification --> roles) my account is set as admin.
How can I be an admin? i never had the chance to log in as admin/admin…
Here are my configs:
nagvis.ini.php in /usr/share/nagvis/etc :
nagvis.conf in /etc/httpd/conf.d :
# NagVis Apache2 sample configuration file
Alias /nagvis "/usr/share/nagvis/share"
<Directory "/usr/share/nagvis/share">
Options FollowSymLinks
AllowOverride None
# default: Order allow,deny
# Allow from all
Require IP 10.0
# To enable Nagios basic auth on NagVis use the following options
# Just uncomment it. Maybe you need to adjust the path to the
# Auth user file.
# If you use the NagVis internal auth mechanism based on the web
# for you won't need this.
#AuthName "NagVis Access"
#AuthType Basic
#AuthUserFile /usr/share/icinga2/etc/htpasswd.users
#Require valid-user
# With installed and enabled mod_rewrite there are several redirections
# available to fix deprecated and/or wrong urls. None of those rules is
# mandatory to get NagVis working.
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /nagvis
# Use mod_rewrite for old url redirection even if there are php files which
# redirect the queries itselfs. In some cases the mod_rewrite redirect
# is better than the php redirect.
# Using the php redirect seems to be better in some cases where https/http servers
# are mixed. For example in OMD setups where using apache own mode and https in the
# frontend and http in the backend apache servers.
# Disabling this redirect by default in the hope that the php direct works better.
#RewriteCond %{REQUEST_URI} ^/nagvis(/config\.php|/index\.php|/|)(\?.*|)$
#RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/%1%2 [R=301,L]
# Redirect old regular map links
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/(wui|nagvis-js)
RewriteCond %{QUERY_STRING} map=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Map&act=view&show=%1 [R=301,L]
# Without map= param
RewriteCond %{REQUEST_URI} ^/nagvis/frontend(/wui)?/?(index.php)?$
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php [R=301,L]
# Redirect old rotation calls
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/nagvis-js
RewriteCond %{QUERY_STRING} !mod
RewriteCond %{QUERY_STRING} rotation=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Rotation&act=view&show=%1 [R=301,L]
</IfModule>
</Directory>
I played around with Allow from all etc. but it did not change the appearance of my nagvis
If i can provide more details please tell me, i really appreciate every hint!
Thanks in advance!
