parad1se
(David)
1
Hi Folks,
I try to upgrade Icinga2-2.13.3 and IcingaWeb2-2.10.1 to Icinga2-2.13.5-1 and IcingaWeb2-2.11.1.
I’m running on CentOS 7.9 with: mariadb-server-5.5.68-1.el7.x86_64 and
mariadb-5.5.68-1.el7.x86_64.
After a successful yum update, I try to upgrade the DB schema according to the Upgrading to Icinga Web 2.11.x guide.
The error I’m getting is:
mysql -u root -p icingaweb2 < /usr/share/doc/icingaweb2/schema/mysql-upgrades/2.11.0.sql
Enter password:
ERROR 1071 (42000) at line 8: Specified key was too long; max key length is 767 bytes
According to line 8 of the schema upgrade 2.11.0.sql its:
ALTER TABLE icingaweb_group_membership
CONVERT TO CHARACTER SET utf8mb4;
What does it mean and how can I fix that?
Many thanks in advance!
Best resgards
David
parad1se
(David)
2
It seems that adding the following mariadb parameters solves the problem:
/etc/my.cnf:
innodb_file_per_table=true
innodb_large_prefix=1
innodb_file_format=Barracuda
Enter password:
No errors appeared.
parad1se
(David)
3
@theFeu
Do you experience the same bug after the schema update and the fix?
Best regards
David
