I’ve raised an issue here about getting an error when trying to load the reporting module: https://github.com/Icinga/icingaweb2-module-reporting/issues/75
As far as I can see my MySQL server’s time zone is set to SYSTEM. Does it need to be set to another value for Icingaweb2 to work properly? I can’t see anywhere in the documentation that specifies it needs to be something else?
Thanks,
Will.
