Multiple Microsoft SQL Instances with multiple databases - Using director
Hi All
New to the community. I hope you can assist me.
How can I use director to monitor multiple Microsoft SQL instances on a single host.
We have multiple instances of SQL running on our data server, each one of those instances have multiple databases within those databases we have a stored procedures that runs multiple checks against the databases.
I created a simple check in director that uses a powershell script with parameters.
On director is a simple command with custom variable that points to the shellscript on the SQL server and passes a few arguments.
Something like this:
ps_command & ‘C:\Program Files\ICINGA2\sbin\customprpsqlcheck.ps1’ -Instance server\sqldevelopment -Database DEV1 -Test mydevicesessions
The challenge is that I don’t want to create checks for each SQL Instance, Database and Test … I’m going to end up with 500 individual “checks” like the sample command above, there are multiple instances with multiple databases containing multiple stored procedures with multiple “Tests”.
How can I get this one check I created to run over all instances and DB’s without having to create every check individually?
Here is an example I found on how to do it using conf files and mysql in Icinga2 “https://icinga.com/blog/2017/06/12/how-to-monitor-your-mysql-servers-with-icinga-2/”, but how do I go about this using Microsoft SQL and Director?
There must be a way in director to tell it to duplicate a specific check so that it creates a new check with new parameters i.e (-Instance server\sql2dev -Database DEV2 -Test mydeviceclocks) for each test in each database on every SQL instance.
Any assistance would be appreciated.
Regards
Francois
the problem I see here is that icinga doesn’t know which instances are available.
I think you have 2 possibility:
  1. adapt your ps1 file to iterate over all instances, and execute your check procedure for every instance via powershell.(one services)
    https://www.sqlshack.com/six-methods-to-automatically-discover-sql-server-instances/
  2. write a powershell script that interates over all instances and create the 500+ services in icinga director via icingadirector restapi call
Thank you @moreamazingnick for the reply.
option 1: This returns all the results in one service and is unmanageable, there is no way to separate the results by instance and database. I need to generate a separate service for each test in each instance in each database.
options 2: This might help me – write a powershell script that iterates over all instances and create the 500+ services in icinga director via icingadirector restapi call.
  • Where can I find information on how this works? Any examples available?
Thank you, your ongoing assistance is greatly appreciated.
  • start with creating on reference service in icinga director for reference host.
    Hint, do not use any spaces or special chars, or take care of proper encoding
  • perform a GET on this url with basic auth, use a icingaweb2 username/password that has director RW access or full access :
    “https://” + icinga_instance + ‘/icingaweb2/director/service?host=’ + reference_host + “&name=” + reference_service
  • look at the response, now you know what icinga director expects as a service object for your service.
  • change object_name and host and vars->your_instance_var
    you can json decode it manipulate it, and POST it to:
    “https://” + icinga_instance + ‘/icingaweb2/director/service?host=’ + other_host
  • if run this in a loop on a host with sql instances for each instance → you get services for all instances on this host
Hi @moreamazingnick
Please can you provide more detail for this line: * start with creating on reference service in icinga director for reference host. Hint, do not use any spaces or special chars, or take care of proper encoding
Should I create a Host and service in director and use it in the following api call:
"https://myserver.company.com/icingaweb2/director/service?host=thehosticreated&name=theservicecreated”
when I try to perform the GET I get error:
Invoke-WebRequest : The underlying connection was closed: An unexpected error occurred on a send.
yes sound good but post your webrequest script because the error is unspecific
Hi @moreamazingnick
Here is the script:
$securepassword = ConvertTo-SecureString “password********” -AsPlainText -Force
$credentials = New-Object System.Management.Automation.PSCredential(“icingaweb2”, $securepassword)
[System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
Invoke-WebRequest -Uri “https://monitordir.company.co.za/icingaweb2/director/service?host=panther.company.co.za&name=SQLCustomCheck” -Credential $credentials
that does not work on my system
try that instead
add-type @"
    using System.Net;
    using System.Security.Cryptography.X509Certificates;
    public class TrustAllCertsPolicy : ICertificatePolicy {
        public bool CheckValidationResult(
            ServicePoint srvPoint, X509Certificate certificate,
            WebRequest request, int certificateProblem) {
            return true;
Invoke-WebRequest -Uri "https://monitordir.company.co.za/icingaweb2/director/service?host=panther.company.co.za&name=SQLCustomCheck" -Credential $credentials -ContentType 'application/json' -Headers @{"accept"="application/json"}
Hi @moreamazingnick
When you run Invoke-WebRequest or Invoke-RestMethod command, sometimes you get the error “The underlying connection was closed: Could not establish trust relationship for the SSL/TLS secure channel .” because there could be a certificate issue or the required windows version doesn’t support the TLS or SSL version. You can use the command to bypass this error.
I still get the same error even if I remove line: [System.Net.ServicePointManager]::CertificatePolicy = New-Object TrustAllCertsPolicy
the error is referencing the https:// line see below so something not working in the Https:// line
At line:6 char:1
  • Invoke-WebRequest -Uri "https://monitordir.company.co.za/icingaw
  •   + CategoryInfo          : InvalidOperation: (System.Net.HttpWebRequest:HttpWebRequest) [Invoke-WebRequest], WebException
      + FullyQualifiedErrorId : WebCmdletWebResponseException,Microsoft.PowerShell.Commands.InvokeWebRequestCommand
nobody said anything about removing a line.
the script in my post works on my server.
try that:
[Net.ServicePointManager]::SecurityProtocol = "tls12, tls11";
HI @moreamazingnick
im using this scrypt:
$securepassword = ConvertTo-SecureString “*****ppassword” -AsPlainText -Force
$credentials = New-Object System.Management.Automation.PSCredential(“director”, $securepassword)
add-type @"
using System.Net;
return true;
[Net.ServicePointManager]::SecurityProtocol = “tls12, tls11”;
Invoke-WebRequest -Uri “https://monitordir.company.co.za/icingaweb2/director/service?host=panther.company.co.za&name=SQLCustomCheck” -Credential $credentials -ContentType ‘application/json’ -Headers @{“accept”=“application/json”}
error i get now:
add-type : Cannot add type. The type name ‘TrustAllCertsPolicy’ already exists.
At line:3 char:1
  • add-type @"
  •   + CategoryInfo          : InvalidOperation: (TrustAllCertsPolicy:String) [Add-Type], Exception
      + FullyQualifiedErrorId : TYPE_ALREADY_EXISTS,Microsoft.PowerShell.Commands.AddTypeCommand
At line:16 char:1
I just executed that and it works like a charm:
add-type @"
    using System.Net;
            return true;
hi @moreamazingnick
Ok, I tried this again and now I get a different error:
Invoke-WebRequest : The remote server returned an error: (401) Unauthorized.
post you script and use the </> preformat tags
Hi @moreamazingnick
$securepassword = ConvertTo-SecureString "***password" -AsPlainText -Force
$credentials = New-Object System.Management.Automation.PSCredential("icingaweb2", $securepassword)
add-type @"
    using System.Net;
            return true;
now try to login in icingaweb2 with your browser using the credential in your script
Hi @moreamazingnick
It does not allow me to login using those credentials.
Those credentials are for the API
you want to connect to https://monitordir.company.co.za/icingaweb2
so you need to use icingaweb2 credentials.
the icingaweb2 user needs to have permission for the director
Hi @moreamazingnick
Ok I understand, I used my user and password for icingaweb2 in the script and it went pass the previous error but now it returns another error:
Invoke-WebRequest : {“status”:“error”,“message”:“Uncaught Error: Call to a member function toString() on null in
/usr/share/icingaweb2/modules/director/application/controllers/ServiceController.php:254\nStack trace:\n#0
/usr/share/icingaweb2/modules/director/library/Director/Web/Controller/ObjectController.php(497):
Icinga\Module\Director\Controllers\ServiceController->loadObject()\n#1
/usr/share/icingaweb2/modules/director/library/Director/Web/Controller/ObjectController.php(70):
Icinga\Module\Director\Web\Controller\ObjectController->loadOptionalObject()\n#2
/usr/share/icingaweb2/modules/director/application/controllers/ServiceController.php(46):
Icinga\Module\Director\Web\Controller\ObjectController->init()\n#3
/usr/share/php/Icinga/Web/Controller/ActionController.php(170):
Icinga\Module\Director\Controllers\ServiceController->init()\n#4 /usr/share/php/Icinga/Web/Controller/Dispatcher.php(59):
Icinga\Web\Controller\ActionController->__construct()\n#5
/usr/share/icingaweb2/library/vendor/Zend/Controller/Front.php(937): Icinga\Web\Controller\Dispatcher->dispatch()\n#6
/usr/share/php/Icinga/Application/Web.php(304): Zend_Controller_Front->dispatch()\n#7
/usr/share/php/Icinga/Application/webrouter.php(109): Icinga\Application\Web->dispatch()\n#8
/usr/share/icingaweb2/public/index.php(4): require_once(’…’)\n#9 {main}\n thrown”}
At C:\Users\francois.bruere\Documents\TEST.ps1:16 char:1
  • Invoke-WebRequest -Uri "https://monitordir.company.co.za/icingaweb2/director/serv
can you call “https://monitordir.company.co.za/icingaweb2/director/service?host=panther.company.co.za&name=SQLCustomCheck” with your browser?
  • What icingaweb2 version do you use?
  • What director version do you use?
Please use the formating tags!
