Hello Icinga community o/
Could I run multiple Icinga2 agent environments ?
Actually I want to run on the same node, two different icinga2 agent configurations. Is such a thing possible ?
I have two completely different Icigna 2 master setups ( eg: : two different organizations/companies ) and each one wants to do their own agent checks.
I tried the following..
- Create CSR and Certificate for the node.
icinga2 pki new-cert --cn icinga-agent.example \
--key /var/lib/icinga2/certs/icinga-agent.example.key \
--cert /var/lib/icinga2/certs/icinga-agent.example.crt
- Request the master certificate from the master host (
icinga2-master1.example.com) and store it asicinga2-master1.example.com
icinga2 pki save-cert \
--trustedcert /var/lib/icinga2/certs/icinga2-master1.example.com \
--host icinga2-master1.example.com
- Node setup for master1
icinga2 node setup --ticket 954....3315 \
--endpoint icinga2-master1.example.com \
--zone icinga-agent.example \
--parent_zone master \
--parent_host icinga2-master1.example.com \
--trustedcert /var/lib/icinga2/certs/icinga2-master1.example.com.crt \
--accept-commands --accept-config \
--disable-confd
systemctl restart icinga2
Now everything works perfect for master1.
But I also want another one Icinga2 master to monitor this box, so I do the following:
--trustedcert /var/lib/icinga2/certs/icinga2-master2.example.com \
--host icinga2-master2.example.com
icinga2 node setup --ticket 123....456 \
--endpoint icinga2-master2.example.com \
--parent_host icinga2-master2.example.com \
--trustedcert /var/lib/icinga2/certs/icinga2-master2.example.com.crt \
--disable-confd
After that, this node only connected to icinga2-master2.example.com.
I want to send agent checks to both : icinga2-master1.example.com & icinga2-master2.example.com.
ls -alh /var/lib/icinga2/certs/
total 40K
drwxr-x--- 2 icinga icinga 4.0K Sep 16 00:25 .
drwxr-x--- 5 icinga icinga 4.0K Sep 16 00:26 ..
-rw-r--r-- 1 icinga icinga 1.8K Sep 15 22:56 icinga2-master1.example.com.crt
-rw-r--r-- 1 icinga icinga 1.7K Sep 16 00:25 ca.crt
-rw-r--r-- 1 icinga icinga 1.8K Sep 16 00:25 icinga-agent.example.crt
-rw-r--r-- 1 icinga icinga 1.8K Sep 15 22:55 icinga-agent.example.crt.orig
-rw------- 1 icinga icinga 3.2K Sep 16 00:25 icinga-agent.example.key
-rw------- 1 icinga icinga 3.2K Sep 15 22:55 icinga-agent.example.key.orig
-rw-r--r-- 1 icinga icinga 1.8K Sep 15 23:00 icinga2-master2.example.com.crt
-rw------- 1 icinga icinga 40 Sep 16 00:25 ticket
Related
I read the following, but I can not understand if this is impossible…
