Good morning,
I was just wondering: can we have multiple eventhandlers per service check? If yes, how would the format in the service config look like?
Good morning,
As I know only one event handler is possible. More information can be found here: Monitoring Basics - Icinga 2
But what you can do is to put some if-then-else or switch/case blocks in your event handler script, where you can handle different situations.
Yes, that would be my Plan-B.
like: have some custom service variable in the service and check on that in the eventhandler script. I’ll think about that.
Now I would need to find out how to grab the custom service variable in a script…
That’s easy. Pass the macros (e.g. $service.state$) you need as arguments to your script
Okay so, for the records
services.conf
vars.event_options = "pager_duty"
commands.conf
"-e" = "$service.vars.event_options$"
eventhandler script
19 while getopts ":o:t:g:e:n:s:a:h:g:v" opt; do
20 case $opt in
21 t) SERVICE_TYPE=$OPTARG >&2 ;;
22 s) SERVICE_STATE=$OPTARG >&2 ;;
23 a) SERVICE_CHECK_ATTEMPT=$OPTARG >&2 ;;
24 h) HOST_NAME=$OPTARG >&2 ;;
25 n) SERVICE_NAME=$OPTARG >&2 ;;
26 g) HOST_GROUPS=$OPTARG >&2 ;;
27 o) SERVICE_OUTPUT=$OPTARG >&2 ;;
28 e) EXTRA_VAR=$OPTARG >&2 ;;
29 \?) echo "Invalid option: -$OPTARG" >&2
30 exit $STATE_UNKNOWN
31 ;;
32 :) echo "Option -$OPTARG requires an argument." >&2
33 exit $STATE_UNKNOWN
34 ;;
35 esac
36 done
if [ "$EXTRA_VAR" == "pager_duty" ]; then
/bin/logger "Alert - $DESCRIPTION"
fi
