I am setting up a multi-tenant environment. Currently 1 master with 2 satellites, but there will be more satellites in the near future (maybe up to 20).
I have created a service template in the global-templates zone, so I should be able to use this template with all satellites.
If I use a service apply rule, this all works fine. Now I have typical 1 customer related service checks, which I would like place under the “Single Services”.
In my example it is a certificate check using check_http.
This single service should use the global template check_http and as a service check exist on 1 satellite only.
But if I do it this way, I get an error when deploying my configuration:
client01 - bg-web1!24x7P2_check_https-cert-webmail.domain.nl' cannot be put into global zone 'director-templates'
There is no option to change the zone for this single service.
What is the best way to do this, using the service apply rules or is there a better way to keep things more simple and keep a better overview?
Thank you very much in advance…
