Hi, I’m trying to figure out more about performance data.
I notice on icingaweb2 the service ‘disk’ is able to monitor all disks and show the performance data of all of them with the cake like graph.
I tried to run the check_disk plugin on 2 devices to check it’s output and here’s an example:
/usr/lib/nagios/plugins/check_disk --units GB -w 5 -c 10 --path /opt/zimbra --path /
DISK OK - free space: /opt/zimbra 59 GB (60% inode=98%); / 14 GB (78% inode=90%);| /opt/zimbra=38GB;93;88;0;98 /=3GB;14;9;0;19
I see performance data has a csv like format (label=value;value;value;value;value) and on icingaweb2 I see the results as:
Label Value Max Warning Critical
So, 5 values passed by the plugin, 4 values shown by icingaweb2.
Looks like the ‘0’ is not considered or has a meaning I don’t know.
Checking documentation I found 8 value types:
label value counter unit crit warn min max
If I create my own plugin, how shall performance data be printed out?
I’m confused by the 8 values type reported in the documentation and the 5 printed by check_disk plugin.
Thank you.
