Please describe your problem as detailed as possible and don’t forget to use a meaningful title
i am using check_smart.pl to monitor the smart status of drives.
Everything has been working as expected but recently we added a server with an adaptec raid card (aacraid).
check_smart.pl -i aacraid,00,00,00 -d /dev/sda
and
check_smart.pl -i aacraid,00,00,01 -d /dev/sda
shows me the status of both physical drives.
What would be best practice to configure the two different interface values?
and in the host definition we define the according values ike:
vars.my_disk_smart_device = “/dev/sda”
vars.my_disk_smart_interface = “aacraid,00,00,00”
vars.my_disk_smart_interface = “aacraid,00,00,01”
what of course does not work…
How to define the interfaces in a simple yet effective way?
Thanks!
