I just started to use icinga2. The following problem is concerns me:
Monitoring a local saslauthd using testsaslauthd is not working correctly.
I created a new check
check_saslauthd is some old perl check from nagios and is doing the job.
Icinga2 is just showing me âSASLAUTHD CRITICAL - CRITICAL: authentication failed for XXâ.
At the command line using the same parameter everything is working.
a) How can I check if the command is execute on the node and not the server ?
b) How can I get some debug information (command line options ,exit code, âŚ)
I donât know the check âcheck_saslauthdâ. But in my experience itâs very often a security reason why something not work. Like the icinga-user is not allowed to run the check or the script needs more permission to get some data. e.g. Redhat Systems are using SELinux. If this is turned on maybe the script wants to do something what it is not allwed.
âauthentication failedâ sounds like a permission problem or wrong user/password.
If you use the director, the executed commandline is displayed in the webinterface (the âinspectâ link on the service detail page)
If you donât use director, you can find the commandline it either in the debuglog or via the api console.
Icingaweb2 also shows you a value called check source, this is the machine where the command is executed.
Another source of errors can be the variable names user and password
If there are other checks for the same system that use the same vars with other values, the macro resolver could confuse them. Better put check-command-exclusive macros into your checkcommand, like for example sasl_user and sasl_password
So thatâs the command object, but can we see the service object? If itâs meant to be run on the client node and not the Icinga parent, you would need something like:
