Monitoring Router using icinga2
Hi, I am new in icinga2.
I am trying to monitoring the router. For this, I have added in :
nano /etc/icinga2/conf.d/hosts.conf
object Host “Router” {
address = “myRouterIP”
check_command = “hostalive”
The output of icinga ui is : PING OK - Packet loss = 0%, RTA = 0.45 ms
But I want to monitor all the necessary information of router using this( Connectivity (check_ping) Websites (check_http) Disk usage (check_disk) CPU usage (check_load) Memory usage (check_swap) Uptime (check_uptime) File size (check_file_size.sh) File age (check_file_age) File shares (check_file_size) Log files (check_log) Non-standard ports (check_port) Mail (check_smtp, check_mailq,more) DNS (check_dns) Certificate expirations (check_http) Backup software (check_proc) AV software (check_proc) Check on printer (check_snmp) ).
I have heard about all but I don’t know how to use this for getting info of router.
What type of router do you use?
Routers and other network devices usually allow monitoring via SNMP, ssh or telnet.
If your router is Linux based, you can use service checks like on a “normal” host.
Be aware that excessive checks can consume many ressources on your router
and decrease performance.
yes, But I don’t know how to monitoring via SNMP.
I just found that to monitor router:
But it’s not giving what I actually want.
I would suggest to start reading the docs from the begining to the end. Of course focus on Service Monitoring and especially SNMP.
This is not something that can be covered in a couple of lines in the discussion forum.
George
you should try the centreon plugin suite and create custom commands at commands.conf. This plugin suite has very great addons for routers etc.: https://github.com/centreon/centreon-plugins
usually a network device like a router is read out via SNMP. Certain SNMP values or interface statistics are checked and alerted if necessary.
With Thola exists a check plugin which takes over the communication with the network device:
or
https://thola.io
