Hi guys,
I would like to know how could I monitor IS-IS for Cisco because I tried to search around but I found nothing…
Someone could kindly help me?
Thanks in advance for the support
Hi guys,
Hallo @snuz, welcome to Icinga community. There are several nagios plugins that allow you to do this but you can heck out check_nwc_health plugin in Icinga Exchange.
Is there a documentation to do this?
I don’t know what exactly you mean but here is the Icinga plugin documentation.
https://icinga.com/docs/icinga2/latest/doc/10-icinga-template-library/#nwc_health
I tried to do this:
object CheckCommand "check_isis_nei" {
import "plugin-check-command"
command = [ "perl" , PluginDir + "/check_isis" ]
arguments = {
"-r" = "0.0.0.0"
"-c" = "public"
"-n" = "1.1.1.1%Router"
vars.check_address = "$address$"
But it doesn’t work
Also because moreover I have not found anything on the documentation check_nwc_health regarding IS-IS
For example for BGP there is list-bgp-peers, watch-bgp-peers, bgp-neighbors. For IS-IS there is nothing…
