yungd
(Duely Yung)
July 26, 2019, 8:59pm
1
I want to monitor each individual ports on a network switch and I’m able to do so with the following code:
apply Service for (interface => config in host.vars.snmp_interfaces) {
import "generic-service"
display_name = "Network traffic on " + config.snmp_interface_label
check_command = "snmp-interface"
vars.snmp_interface_ifname = "true"
vars.snmp_interface_noregexp = "true"
vars.snmp_warn = "100,100"
vars.snmp_crit = "100,100"
vars += config
assign where host.vars.snmp_address
On the host configuration file, I have the following code:
vars.snmp_interfaces["snmp-int-port1"] = {
snmp_interface = "1"
snmp_interface_label = "port 1"
The problem is that since the network switch has 52 ports, I’ll need to create 52 entries for the above code. Is there a simpler and more efficient way of doing this?
yungd
(Duely Yung)
July 29, 2019, 4:42pm
2
I’ve found a better way around this by creating a template and copy and paste the snmp_interfaces[""] code with the updated port number. By doing this, I should be able to reuse this template for other Network switch. Also, it will keep my host configuration file cleaner.
dnsmichi
(Michael Friedrich)
July 30, 2019, 9:26am
3
can you share the concrete solution for others looking into your topic too?
Thanks,
yungd
(Duely Yung)
July 30, 2019, 2:16pm
4
Sure!
Basically, I have created a template that contains the interface information named int-ports-template.conf
template Host "int-ports-template" {
snmp_interface_label = "port 01"
grafana_graph_disable = true
vars.snmp_interfaces["snmp-int-port2"] = {
snmp_interface = "2"
snmp_interface_label = "port 02"
vars.snmp_interfaces["snmp-int-port3"] = {
snmp_interface = "3"
snmp_interface_label = "port 03"
The Host configuration file will simply import the above template.
object Host "network-switch" {
import "generic-host"
import "int-ports-template"
address = "x.x.x.x"
groups = [ "network" ]
vars.hostgroup = "Network"
vars.snmp_v3 = true
The Service configuration file remains the same.
vars += config
bisontim
(Mario)
December 9, 2025, 1:24pm
5
Is it possible with Icinga Director?
I mean, the: display_name = "Network traffic on " + config.snmp_interface_label
I don’t think it’s available with Director
bberg
December 9, 2025, 3:04pm
6
Dictionary Support in the Icinga Director is not yet included, but will come in one of the next releases.
