Monitoring Hyper-V
Hi everyone,
I’m currently dealing with monitoring Microsoft Hyper-V clusters. In that process I want to collect some input and insights regarding this. My goal is to find out about what we need to take care of when considering a Hyper-V monitoring solution for our Icinga Powershell Framework.
I have some questions below that can help us, but feel free to add anything else that comes to your mind.
  • How do you monitor Hyper-V Infrastructure today?
  • What exactly do you monitor regarding Hyper-V?
  • What is missing in your current solution?
  • Which findings do you expect to get from a monitoring for Hyper-V?
  • Are you able/allowed to install software on your Hyper-V hosts?
  • Do you have any other feedback or concerns?
Thank you!
Hello Blerim,
i monitor
  • ClusterStorages usage
  • VM Status (online/offline)
  • Memory usage
  • CPU Usage
  • VM Diskpace (configured disk size vs. real space used on cluster storage.
  • Configured CPUs, Memory etc.
And many more things, see my dashboard :slight_smile:
other overview:
Anf the last one is a mix of AIX/HyperV
On the Hyper-V hosts I monitor typical Windows checks (cpu, mem, disk, essential services).
For Hyper-V especially I also monitor the Cluster-shared Volumes(with the “ancient” check_wmi_volume.vbs ^^) and the age of VM checkpoints (with a self-written PowerShell script).
Also the performance counter for logical processor usage in %, because it is more reliable than the NSclients cpu check)
The VMs are monitored separately, not via the Hyper-V hosts.
In older setups I used the NSClient, in newer setups the Icinga 2 Agent.
Hi @bsheqa
At this time we reconstruct monitoring logic out Hyper-V Cluster (Failover Cluster) and stand alone host.
we monitor host, VM and cluster status
some performance count we take from Nike Eales blog
https://docs.microsoft.com/ru-ru/archive/blogs/neales/hyper-v-performance-cpu
on Hyper-V host may be install monitoring and backup tools or agent
Hi Anon
Have you configured your icinga in Windows server or linux server? I am searching for some docs to confgure hyperv cluster in icinga linux server
Arun Thomas
