Maybe this question is old but I don’t find any clear answer.
I’m using docker compose example (docker-compose Icinga) to deploy icinga.
My question is clear : How to configure check_disk service to check space of a protected directory (need to have rights to access it) on a remote host.
Here is the error I got :
DISK CRITICAL - /var/lib/docker is not accessible: No such file or directory
This is the command as displayed in the icinga web under services/source :
‘/usr/lib/nagios/plugins/check_disk’ ‘-c’ ‘10%’ ‘-w’ ‘20%’ ‘-X’ ‘none’ ‘-X’ ‘tmpfs’ ‘-X’ ‘sysfs’ ‘-X’ ‘proc’ ‘-X’ ‘configfs’ ‘-X’ ‘devtmpfs’ ‘-X’ ‘devfs’ ‘-X’ ‘mtmfs’ ‘-X’ ‘tracefs’ ‘-X’ ‘cgroup’ ‘-X’ ‘fuse.gvfsd-fuse’ ‘-X’ ‘fuse.gvfs-fuse-daemon’ ‘-X’ ‘fuse.portal’ ‘-X’ ‘fdescfs’ ‘-X’ ‘overlay’ ‘-X’ ‘nsfs’ ‘-X’ ‘squashfs’ ‘-p’ ‘/var/lib/docker’
Inside the icinga docker container I noticed icinga2 process runs with “icinga” user.
In an older post they advice to change the user icinga runs with…but how? what user shall I use?
We have solved this issue with two different approaches - I don’t know which is better, or if there is a best practice.
First you need to check what are the needed privileges to read (why would you need to write, btw?) from /var/lib/docker
First approach: grant the icinga user read permission on /var/lib/docker
You will need to include the icinga user in the docker group, probably.
Second approach: grant the icinga user the permission to run the check_disk command as root (or any user that has the permission to read /var/lib/docker)
You will need to edit the sudoers file.
You will also need to either make a new Icinga command to include “sudo” in front of “check_disk”, or to define a small script that wraps the check_disk command within a new plugin (check_disk_as_root) that you then define as a new command within Icinga.
You will need to adapt your service definition to based on the new command.
