- Icinga Web 2 version
Icinga Web 2 Version 2.11.1
Git commit eecf8d9934cbf30ec063cea4a525b26bfd2bf99a
PHP Version 7.3.29
Git commit date 2022-07-06
Loaded Libraries
icinga/icinga-php-thirdparty 0.11.0
icinga/icinga-php-library 0.9.1
- Used modules and their versions (System - About)
Loaded Modules
director master Configure
doc 2.11.1 Configure
grafana 1.4.2 Configure
incubator 0.17.0 Configure
monitoring 2.11.1 Configure
Web browser used
Firefox -
Icinga 2 version used (
icinga2 --version
icinga2 - The Icinga 2 network monitoring daemon (version: r2.13.4-1) -
PHP version used (
php --version
# /opt/rh/rh-php73/root/usr/bin/php -version
PHP 7.3.29 (cli) (built: Aug 3 2021 12:26:40) ( NTS )
Copyright (c) 1997-2018 The PHP Group
Zend Engine v3.3.29, Copyright (c) 1998-2018 Zend Technologies
- Server operating system and version
System information:
Platform: CentOS Linux
Platform version: 7 (Core)
Kernel: Linux
Kernel version: 3.10.0-1160.71.1.el7.x86_64
Architecture: x86_64
Currently I see the following message: 'Backend icinga is not running ’
Everything looks good.
All systemctl status are green
# icinga2 daemon -C
[2022-07-22 10:24:32 +0200] information/cli: Icinga application loader (version: r2.13.4-1)
[2022-07-22 10:24:32 +0200] information/cli: Loading configuration file(s).
[2022-07-22 10:24:32 +0200] information/ConfigItem: Committing config item(s).
[2022-07-22 10:24:33 +0200] information/ApiListener: My API identity: myservr.fqdn.com
[2022-07-22 10:24:33 +0200] warning/ApplyRule: Apply rule 'by_ssh_check_proc_dsmcad' (in /var/lib/icinga2/api/packages/director/f3f5aa7b-32bb-451d-ba3a-164a11bc743d/zones.d/director-global/service_apply.conf: 1:0-1:39) for type 'Service' does not match anywhere!
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 InfluxdbWriter.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 NotificationComponent.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 IdoMysqlConnection.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 ExternalCommandListener.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 CheckerComponent.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 6 UserGroups.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 4 TimePeriods.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 9 Users.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1490 Services.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 4 ServiceGroups.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 ScheduledDowntime.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 3 Zones.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 4 NotificationCommands.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 3698 Notifications.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 97 Hosts.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 IcingaApplication.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 24 HostGroups.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 23 Comments.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 Downtime.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 Endpoint.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 FileLogger.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 2 ApiUsers.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 250 CheckCommands.
[2022-07-22 10:24:33 +0200] information/ConfigItem: Instantiated 1 ApiListener.
[2022-07-22 10:24:33 +0200] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2022-07-22 10:24:33 +0200] information/cli: Finished validating the configuration file(s).
# cat /etc/icinga2/features-enabled/ido-mysql.conf
* The db_ido_mysql library implements IDO functionality
* for MySQL.
/* library "db_ido_mysql" */
object IdoMysqlConnection "ido-mysql" {
user = "myuser"
password = "<password>"
host = "localhost"
database = "icinga"
MariaDB [icinga]> select instance_id,program_version,is_currently_running,endpoint_name,status_update_time from icinga_programstatus;
| instance_id | program_version | is_currently_running | endpoint_name | status_update_time |
| 1 | r2.13.4-1 | 0 | myservr.fqdn.com | 2022-07-22 07:12:49 |
1 row in set (0.000 sec)
MariaDB [icinga]> select * from icinga_instances;
| instance_id | instance_name | instance_description |
| 1 | default | |
1 row in set (0.001 sec)
My last activities over the past 2 days:
I updated Icinga2, Icingaweb2
changed from rh-php71 to rh-php73
updated the sql schemas incrementally
and today migrated from mariadb 5.5 to mariadb 10.5
Any assistance is greatly appreciated.
Kind regards
Frank
