i guess there is one root cause for several issues.
Any ideas about it would be welcome.
Setup is:
Icinga 2.10.7-1.stretch but Problems were the same from 2.7 on.
icinga2 feature list
Disabled features: compatlog debuglog elasticsearch gelf graphite livestatus opentsdb perfdata statusdata syslog
Enabled features: api checker command ido-pgsql influxdb mainlog notification
icinga2 daemon -C
[2021-02-05 18:43:26 +0100] information/cli: Icinga application loader (version: r2.10.7-1)
[2021-02-05 18:43:26 +0100] information/cli: Loading configuration file(s).
[2021-02-05 18:43:26 +0100] information/ConfigItem: Committing config item(s).
[2021-02-05 18:43:26 +0100] information/ApiListener: My API identity: svr-dbmonitor.local
[2021-02-05 18:43:28 +0100] warning/ApplyRule: Apply rule 'satellite-host' (in /etc/icinga2/conf.d/satellite.conf: 29:1-29:41) for type 'Dependency' does not match anywhere!
[2021-02-05 18:43:28 +0100] warning/ApplyRule: Apply rule 'backup-downtime' (in /etc/icinga2/conf.d/downtimes.conf: 5:1-5:52) for type 'ScheduledDowntime' does not match anywhere!
[2021-02-05 18:43:28 +0100] warning/ApplyRule: Apply rule 'check-smart-attributes' (in /etc/icinga2/conf.d/services.conf: 284:1-284:38) for type 'Service' does not match anywhere!
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 772 Services.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 InfluxdbWriter.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 IcingaApplication.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 32 Hosts.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 FileLogger.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 6 NotificationCommands.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 722 Notifications.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 NotificationComponent.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 2 HostGroups.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 ApiListener.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 61 Comments.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 CheckerComponent.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 20 Zones.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 ExternalCommandListener.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 24 Endpoints.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 ApiUser.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 4 Users.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 239 CheckCommands.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 1 IdoPgsqlConnection.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 3 UserGroups.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 9 ServiceGroups.
[2021-02-05 18:43:28 +0100] information/ConfigItem: Instantiated 3 TimePeriods.
[2021-02-05 18:43:28 +0100] information/ScriptGlobal: Dumping variables to file '/var/cache/icinga2/icinga2.vars'
[2021-02-05 18:43:28 +0100] information/cli: Finished validating the configuration file(s).
Icinga Web 2 Version
2.8.2
Git commit
8a89839af94a247ee2149b2336c73b8251b477c0
PHP Version
7.0.33-0+deb9u10
Git commit date
2020-08-17
Copyright
Loaded modules
Name Version
doc 0.0.0
grafana 1.3.4
monitoring 2.8.2
setup 2.8.2
Problems are:
Host Checks are <Terminated by signal 9 (Killed).> every few hours up to two times an hour.
Remote Icinga instance âfoobar.localâ is not connected to âsvr-dbmonitor.localâ
All clients are reconnecting permanently.
âDurationâ and âAttemptâ fields in nagstamon are reset every 30 to 60 minutes for most of the checks.
Monitoring Health Info is âBackend icinga is not runningâ frequently.
then
icinga has been up and running with PID 57298 for 19m 41s
While this pid is running for 2h 41min:
service icinga2 status
â icinga2.service - Icinga host/service/network monitoring system
ââlimits.conf
Active: active (running) since Fri 2021-02-05 13:41:02 CET; 2h 41min ago
Process: 57159 ExecReload=/usr/lib/icinga2/safe-reload /etc/default/icinga2 (code=exited, status=0/SUCCESS)
Main PID: 57298 (icinga2)
There are I/O read wait peaks on the monitoring server but any other system check results are normal.
Icinga is logging in UTC, right?
icinga_programstatus is updatet regularily:
icinga2db=# set timezone to 'UTC';
SET
icinga2db=# select now(), status_update_time from icinga_programstatus;
now | status_update_time
2021-02-05 17:34:42.974882+00 | 2021-02-05 17:34:35
(1 row)
Rgds, Jens
