Monitoring and Notifications
Hi there
is there a way to assign different notification thresholds for a service?
Concrete example:
I monitor the temperature of a switch, now I want a warning and critical notification, but my boss only wants a message when the critical threshold is exceeded.
Can this be set or do I have to include the service twice in the system?
Or is it possible to set different warning thresholds for different notification groups?
Regards Lars
Hi Lars,
you can limit notifications on the user level.
For that you would create a user template that only has state/types criticaland problem and create a user that imports this template.
The notification template/rule you create has all states/types, warning, critical, ok and problem, recovery, for example.
