Hi! Does anyone by any chance know how to monitor the hosts connected by vpn on the icinga web 2 dashboard?
I don’t regard hosts on VPNs as anything special - it’s just another way of
routing between machines - same as anything behind NAT, for example, which may
not be directly accessible, but is indirectly (or at least in the other
direction, which is good enough for Icinga).
You just need to make sure that something on one end of the VPN can monitor
the things on the other end of the VPN - a hierarchical Master - Satellite -
Agent configuration often works well here.
If you still have questions, please explain your routing / network / VPN setup
sufficiently for us to understand which machines can (and cannot) talk to which
others, and where you have Icinga installed (or in principle could install).
Antony.
hi Antony
what about VPN monitoring of services on a Cisco Fire Power appliance…
is it better to monitor via internal cisco mechanism for VPN Services…
or can it be monitored by icinga2 from the internal interface ( trusted zone ) of the appliance
Requirements: Can icinga2 monitor/alert when VPN services on a Cisco Fire Power is offline and no longer accessible to remote workers
Thanking in advance…
Regards
I would like to ask you to open a new topic for your question instead of replying to an old one like this. That way you inrease the chance of people seeing (and replying) to your question and it is a lot less likely to be overlooked. Thank you!
If you think the original post is relevant to the discussion, you can link to it for more context.
thanks @theFeu
Dually Noted
will do just that, given community best pratices…
Appreciate the feedback
