Monitor specific EventID with Invoke-IcingaCheckEventlog
Hi Community!
Im trying to monitor a specific event with the icinga-for-windows PowerShell-Framework. The command im trying to use is Invoke-IcingaCheckEventlog but i cant’t get it to work propertly
The Event is Microsoft-Windows-SMBServer/Audit with ID 3000 (SMB1 access)
This is the command im using
Invoke-IcingaCheckEventlog -LogName "Microsoft-Windows-SMBServer\Audit" -IncludeEntryType Information -Verbosity 2
I tried severel different arguments (-before, -after, - IncludeEventID, etc.) without any success - it always finds 0 entries. Trying it without the -LogName argument also fails despite it schouldn’t be mandatory
In the Windows Eventlog there are plenty of entries:
Does anyone know what i am doing wrong?
Can you please try to run the Plugin with -DisableTimeCache in Addition and check, if this changes the output?
Please try also to change the log name and replace \ with /, as inside the Screenshot the name is different.
thanks for your suggestions but sadly they didn’t help.
The output with -DisableTimecache stays the same and changing the \ to / results in the plugin not finding the Eventlog at all - see screenshot below:
Do i have to escape the / or \ in any way so it gets interpreted correctly?
When using the Get-WinEvent native command it works correctly (with the /)
What i forgot to mention in my original post:
Icinga Framework Version is 1.4.1
OS ist Windows Server 2019 Standard (English language)
Anything else i can try? It seems like all events that are in “subfolders” are not working properply
Ah, that is the reason why it is not working. We use Get-WinEvent starting with Plugins v1.5.0.
Iassume this is the reason why this does not work. Would it be possible to update to 1.5.2 / 1.5.1 and check if this behavior is fixed?
That’s it! I updated my Framework and Plugins to 1.5.x and it’s working as it should:
Sometimes it’s just the simple things - like updating your software :slight_smile:
Thanks a lot for your help - have a nice weekend!
