Hello Team,
We have recently moved our corporate websites behind CDN (Content Delivery Network). There are around 30 website i.e. per country. What is the best way to monitor them?
I can create the monitors with static IPs i.e. a dummy host with check_http command but there are multiple IPs to the site and I could not find a way to issue check-command without ‘-I’ parameter.
Could someone pls advise.
Regards,
Sudhir
are all websites on the same webserver or different. Or does the CDN uses different webserver/sites per country?
Regards,
Carsten
Hello Carsten,
All websites are on the same webserver. As of now I have created dummy hosts for all websites and added individual service using check_http to all of them.
The executed command looks like this - ‘/usr/lib64/nagios/plugins/check_http’ ‘–sni’ ‘-H’ ‘www.website.in’ ‘-I’ ‘www.website.in’ ‘-S’ ‘-e’ ‘HTTP/1.1 200 OK’ ‘-s’ ‘India’
Regards,
Sudhir
