I am trying to Monitor HP ilo4 via SNMP, I have downloaded check_snmp plugin from Nagios and when i check via the script I get below error and when I tried with snmpwalk I get Timeout error.
yes I have already tried with check_il02_health, but i get error you may need to install the Nagios::Plugin module though it installed.
Can’t locate Nagios/Plugin.pm in @INC (you may need to install the Nagios::Plugin module) (@INC contains: /etc/perl /usr/local/lib/x86_64-linux-gnu/perl/5.26.1 /usr/local/share/perl/5.26.1 /usr/lib/x86_64-linux-gnu/perl5/5.26 /usr/share/perl5 /usr/lib/x86_64-linux-gnu/perl/5.26 /usr/share/perl/5.26 /usr/local/lib/site_perl /usr/lib/x86_64-linux-gnu/perl-base) at ./check_ilo2_health.pl line 178.
BEGIN failed–compilation aborted at ./check_ilo2_health.pl line 178.
