Hello all,
I need help to define the check command for the check_vnx_usage plugin.
I would like to monitor our storage system and therefor have found the plugin below.
Now I need a sample check command of the plugin since it was not given on the website.
Regards
Hey,
Scroll down, the readme has the content:
# 'check_vnx_usage' command definition
define command{
command_name check_vnx_usage
command_line $USER1$/check_by_ssh -t 40 -q -l nasadmin -H $HOSTADDRESS$ -C "/home/nasadmin/check_vnx_usage.py -P -w $ARG1$ -c $ARG2$"
@EmmaTinten Icinga(1) is deprected, i think he wants a command configuration for icinga2.
@cooljay here you go, put it into your global-templates dir on first master or if you like pain go for it in director
object CheckCommand "vnc_usage" {
command = [ PluginDir + "/check_vnc_usage" ]
arguments = {
"-p" = {
value = "$vnc_usage_path$"
description = "path of a particular file system to be monitored (default: none)"
required = true
"-w" = {
value = "$vnc_usage_warning$"
description = "consumption warning threshold (default: 80%)"
"-c" = {
value = "$vnc_usage_critical$"
description = "consumption critical threshold (default: 90%)"
"-P" = {
set_if = "$vnc_usage_perfdata$"
description = "enables performance data (default: no)"
vars.vnc_usage_perfdata = true //we want always perfdata :)
Regards,
Carsten
