how do you add chrony (NTP) to be monitored in Icinga2 WEB GUI?
I tried adding in services.conf chrony and chronyd:
apply Service “chronyd” {
import “generic-service”check_command = “chronyd”
assign where host.name == NodeName
But it just seems wrong, and doesn’t want to restart the icinga2.service then.
“Job for icinga2.service failed because the control process exited with error code. See “systemctl status icinga2.service” and “journalctl -xe” for details.”
nov. 03 10:09:41 %server% systemd[1]: Failed to start Icinga host/service/network monitoring system.
Any ideas?
When I try:
apply Service “ntp_time” {
import “generic-service”check_command = “ntp_time”
I get it showing in the WEB GUI, but with error:
CRITICAL: No response from NTP server
In chrony.conf i added allow IP on 127.0.0.1 and the NTP server + the NTP servers giving the time like 3.europe.pool.ntp.org.
