About
The Module for vSphere grants the ability to view and add Host information from an vSphere instance into Icinga Web2.
This is achieved via access to the API of the vSphere Instance.
The Module has several perquisites which need to be met before it can be successfully work.
Prequisites
Other Modules which need to be installed before the vSphere Module can work:
Module reactbundle can be found here (>= 0.4) (Icinga Web 2 module)
Module ipl (Icinga php library) can be found here (>= 0.1) (Icinga Web 2 module)
Module Incubator can be found here (>= 0.1) (Icinga Web 2 module)
Module Director can be found here (>= v1.6) (Icinga Web 2 module)
Installation
How to install the module can be found here
How to get started with the vSphere Module can be watched here
To Do’s
We would like to know how our fellow community members integrated the vSphere module, please share your how to’s and guides in
written or visual
form.
