Hi guys,
we have successfully added our 3 vcenter in icingaweb2. Unfortunately, only one of the three vcenter displays the virtual machines
Datastores, ESXer, hardware information are available, only the virtual machines missed.
Is there a debug option?
The tree view shows VMs
icingacli vspheredb daemon run --trace --debug
Task virtualMachines failed: Storing virtual_machine[fW4MĹYŃ]] failed: SQLSTATE[23000]: Integrity constraint violation: 1048 Column âguest_tools_running_statusâ cannot be null, query was: INSERT INTO virtual_machine (uuid, vcenter_uuid, annotation, hardware_memorymb, hardware_numcpu, hardware_numcorespersocket, template, bios_uuid, instance_uuid, version, connection_state, online_standby, paused, guest_id, guest_full_name, guest_state, guest_host_name, guest_ip_address, guest_tools_status, guest_tools_running_status, resource_pool_uuid, runtime_host_uuid, runtime_last_boot_time, runtime_last_suspend_time, runtime_power_state, boot_network_protocol, boot_order, cpu_hot_add_enabled, memory_hot_add_enabled) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?) {array (
âuuidâ => âfW4MĹYâ . â\0â . âŃ]â,
âvcenter_uuidâ => â
