Hi all,
I am using Manubulon Plugins commands: https://icinga.com/docs/icinga2/latest/doc/10-icinga-template-library/#snmp-manubulon-plugin-check-commands
according to above page, the command snmp-memory should support both Linux and windows
I used the command and created a service with Director and it worked as expected with Linux but I am getting the following error for Windows machines:
ERROR: netsnmp : Received noSuchName(2) error-status at error-index 1.
well… according to the development page from Nagios, http://nagios.manubulon.com/
its mentioned that the command check_snmp_mem does not support windows! and instead another command should be used “check_snmp_storage”
I am confused what to use now? and I would appreciate any hint or help to get my checks working on windows machines.
Thanks in advanced.
Jaber
