Missing debug logs(?)
I am trying to debug a problem that I have with a command. I remember that in the debug logs you could
see how the command is passed onto the agent(with the parameters etc) but now I can’t see anything like that in my debug logs.
Have the logs changed or am I doing something wrong?
did you turn on the debug log feature?
check with:
icinga2 feature list
enable:
icinga2 feature enable [feature name]
look here: Features - Icinga 2
Yes I have it enabled
Hi.
Just an idea:
Did you enable and look at the debuglog on the node where the check gets executed?
Greetings.
You mean where the agent is installed? Unfortunately I don’t have access to that machine.
It’s ok though I managed to debug it but it wasn’t as easy as it would be if I could see the whole command that is executed in the agent.
If you are using the director you should have an “inspect”-button in icingaweb. If you click on it, you’ll see the command which is triggerd :wink:
I didn’t know that, sounds interesting. Where exactly is this button because I don’t seem to find it :sweat_smile:
As I wrote in icingaweb2. You’ll should see this link in the list of the action links from the host/service. But only if the director is installed
