Avoid using the old ARGn attribute naming schema. Instead, use long names following the check command best practice.
Always use command arguments for any given parameter, even if you want to set a default value. This allows for better descriptions and readability and also re-using it in a different context.
object CheckCommand "count_citrix_sitzungen" {
command = [ PluginDir + "/count_citrix_sitzungen" ]
arguments = {
"address" = {
value = "$count_citrix_sitzungen_host$"
description = "The citrix host"
skip_key = true //no key parameter
order = 1 // the argument order is important
"continent" = {
value = "$count_citrix_sitzungen_continent$"
description = "The continent where the citrix sessions should be monitored"
order = 2 // after the address
vars.count_citrix_sitzungen_host = "$address$" // set a default, allow to override on the service level
I’m not sure what value ARG1 describes in your old configuration, I am just guessing that it refers to the continent value. Could also be the count threshold, but that’s up to you to clarify.
