Im currently using an icinga2 with a thousand hosts, lot of services…
Given that i want to use director, I’ve just installed another server and i have it ready without any host, service, etc…
What would be the best way to import the object configuration from the other instance?
I thought i could perform an import via API but i cant find the way.
haven’t used this import source type myself, but it looks like this will request the localhost coreapi, as there are no settings for fqdn, username and pw.
I would maybe use a different way, and use the IDO database from your existing setup as import source. With that, you can extract additional object attributes and sync that accordingly.
Right, forgot about that. I somehow just connected this method with Icinga 1. But as Icinga 2 also has the IDO (same schema even, correct?) this is also a good way.
