Hi all!
I’m migrating our icinga db to a new server. Initially i took an sql dump and loaded everything into the new db, which worked fine.
In between i’ve corrected a lot of things in icinga, so that everything is working again.
Now to finalize the migration, i want to add the latest changes (not so few ) from the source to the new server.
My idea was to take sql entries from the source and add them to the destination, but i failed, because the source does not have the column “uuid” - so the insert fails.
Any chance, i can import the objects (some checks, service templates, hosts, apply rules) with an sql statement, or are there other recommended methos to achieve this?
Thanks, i think that’s a good way to import things.
I’ve completed all steps, and now i could trigger an import run.
What will happen if i run this?
I’ve changed a lot of service and apply rules, which needed some changes in the new environment.
Will this be overwritten if i run this import, or will it be duplicated?
And what would be a way to restrict, what is imported?
the import loads it into a seperate table in icinga director.
the sync rule will write it to icinga director
a sync rule also has property modifier and mapping settings, so there is still a lot of work to do to map all the data. here is the object_name for example.
each of these two have a preview so you can check what’s actually do.
changes to the director are only made after you trigger the sync
