Memory Exhaustion on Check
Hi, I’ve recently installed Icinga2 and when I select “Check Now” against any check, it appears to run, but I get the following error message:
Fatal error: Allowed memory size of 1073741824 bytes exhausted (tried to allocate 20480 bytes) in /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Command/Transport/CommandTransport.php on line 38
Fatal error: Uncaught ErrorException: ob_end_clean(): Failed to delete buffer. No buffer to delete in /usr/share/php/Icinga/Application/Web.php:460 Stack trace: #0 [internal function]: Icinga\Application\ApplicationBootstrap->Icinga\Application{closure}() #1 /usr/share/php/Icinga/Application/Web.php(460): ob_end_clean() #2 [internal function]: Icinga\Application\Web->Icinga\Application{closure}() #3 {main} thrown in /usr/share/php/Icinga/Application/Web.php on line 460
  • Icinga Web 2 version:
    2.12.5
  • Used modules and their versions (System - About)
    Loaded Modules
    |director||1.11.5|
    |doc||2.12.5|
    |icingadb||1.2.2|
    |incubator||0.23.0|
    |migrate||2.12.5|
    |translation||2.12.5|
  • Web browser used
    Firefox Latest
  • Icinga 2 version used (icinga2 --version)
    r2.15.0-1
  • PHP version used (php --version)
    PHP 8.3.6
  • Server operating system and version
    Ubuntu 24.04.3 LTS
nice to see you’re trying Icinga out!
Does this happen on any single check? I mean, you choose a single item and click “Check Now”?
Since you installed this only recently, I assume you also installed and configured the webserver as well just recently. It may be the case that the webserver strips away some of the request url parameters used when issuing the command, causing the backend to run all checks.
If you don’t spot anything suspicious in your webserver configuration, you can post it here, someone might be able to help out with it.
Hi Johannes,
That’s correct. Any single check I select (e.g. a ping check on a single host), and clicking the “Check Now” button, results in that error.
Yes, I’ve recently installed Apache, could you let me know what web server configuration file would be most helpful to post?
Thanks,
Hugh
Use the browser’s DevTools Network tab and watch for a check-now? line after pressing the link.
Note the request URL and compare it to the request in your Apache log.
Maybe you can also get php-fpm to log the next layer and/or get the icingaweb2 to log the received request.
Apologies for the delay in responding, I was dealing with other priorities, but I’d like to get this sorted now.
I’m still having the same issue: any time I click “Check Now” next to any check I get this error:
Fatal error: Allowed memory size of 2147483648 bytes exhausted (tried to allocate 20480 bytes) in /usr/share/icingaweb2/modules/icingadb/library/Icingadb/Command/Transport/CommandTransport.php on line 38
Fatal error: Uncaught ErrorException: ob_end_clean(): Failed to delete buffer. No buffer to delete in /usr/share/php/Icinga/Application/Web.php:460 Stack trace: #0 [internal function]: Icinga\Application\ApplicationBootstrap->Icinga\Application\{closure}() #1 /usr/share/php/Icinga/Application/Web.php(460): ob_end_clean() #2 [internal function]: Icinga\Application\Web->Icinga\Application\{closure}() #3 {main} thrown in /usr/share/php/Icinga/Application/Web.php on line 460
I upped the php memory limit to 2GB, still getting the same problem.
I use the DevTools in my browser to see the check-now? line, and I can see it in the apache log with the correct parameter:
[04/Dec/2025:07:21:42 +0000] “POST /icingaweb2/icingadb/host/check-now?name=icinga HTTP/1.1” 200 740 “http://172.20.228.6/icingaweb2/dashboard” “Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:145.0) Gecko/20100101 Firefox/145.0”
So it looks like apache is receiving the request correctly. This is a brand new apache install, the only thing I’ve changed is increasing the php memory limit.
Any ideas on anything to fix this?
