My Slave is configured to connect to master, that connection is established
[2021-01-12 23:36:44 +0100] information/ApiListener: Sending replay log for endpoint ‘myhost’ in zone ‘master’.
[2021-01-12 23:36:44 +0100] information/ApiListener: Finished sending replay log for endpoint ‘myhost’ in zone ‘master’.
[2021-01-12 23:36:44 +0100] information/ApiListener: Finished syncing endpoint ‘myhost’ in zone ‘master’.
[2021-01-12 23:36:44 +0100] information/ApiListener: Applying config update from endpoint ‘myhost’ of zone ‘master’.
But I don’t see any Host in the Icinga on the satellite, there is no config in /var/lib/api/…
Only on Master I see that notices:
The master cannot reach the satellite - only satellite could reach master. That is configured in the endpoints (and should be working else it wouldn’t connect)
What do I do wrong?
