At the moment I’m in Education, I’ve bought the Icinga-Book and tried my best to fix my problem at work. I Have to setup a satellite with two agents. I can only access the master with icingaweb2.
Version of:
Master(icingaweb2): 2.10.1
Master(icinga2):r2.13.2-1
Satellite: r2.12.3-1
Agent: r2.12.3-1
I’ve checked all ports using telnet and everything is open for 5665. My satellite is in its own network and only reachable over hiddenaddress.myfritz.net
I believe my problem is inside the satellite and/or agents zones.conf. My boss told me, that the master should be fine.
In Director, I’ve created
a zone called “examplezone.local”
Globalzone: no
Parent: master -
an endpoint called “examplesatellite”
address: hiddenaddress.myfritz.net
port 5665
log: log 1h
api user: master
clusterzone: examplezone.local
after that I’ve started to setup the satellite zones.conf:
object Endpoint "hidden-master" {
host = "hidden-master.com"
port = "5665"
object Zone "master" {
endpoints = [ "hidden-master" ]
object Endpoint "examplesatellite.examplezone.local" {
object Zone "examplezone.local" {
endpoints = [ "examplesatellite.examplezone.local" ]
parent = "master"
global = true
global = true
running “icinga2 object list --type Zone” on satellite: (heres maybe the error because no agent visible in endpoints)
Object 'examplezone.local' of type 'Zone':
% declared in '/etc/icinga2/zones.conf', lines 18:1-18:33
* __name = "examplezone.local"
* endpoints = [ "examplesatellite.examplezone.local" ]
% = modified in '/etc/icinga2/zones.conf', lines 19:2-19:57
* global = false
* name = "examplezone.local"
* package = "_etc"
* parent = "master"
% = modified in '/etc/icinga2/zones.conf', lines 20:2-20:18
* source_location
* first_column = 1
* first_line = 18
* last_column = 33
* last_line = 18
* path = "/etc/icinga2/zones.conf"
* templates = [ "examplezone.local" ]
% = modified in '/etc/icinga2/zones.conf', lines 18:1-18:33
* type = "Zone"
* zone = ""
after that I’ve started to setup the agents zones.conf:
object Endpoint "exampleagent.examplezone.local" {
object Zone "exampleagent.examplezone.local" {
endpoints = [ "exampleagent.examplezone.local" ]
parent = "examplezone.local"
global = true
global = true
running “icinga2 object list --type Zone” on agent:
% declared in '/etc/icinga2/zones.conf', lines 9:1-9:33
% = modified in '/etc/icinga2/zones.conf', lines 10:2-10:57
* global = false
* package = "_etc"
* parent = ""
* source_location
* first_column = 1
* first_line = 9
* last_column = 33
* last_line = 9
% = modified in '/etc/icinga2/zones.conf', lines 9:1-9:33
* type = "Zone"
* zone = ""
I really hope you can help me out. At the company, there is nobody who could help me. There was only one, and he left it a few month ago.
Best regards
mdi
