Is there any way in icinga to acknowledge similar kind of alerts at once.
Ritu
Ritu
in Icinga Web 2 you can hold the SHIFT key and select multiple host/services to acknowledge.
Best regards
What @mcktr says and use the filter to select for the services. This can make it even a bit easier.
